volvo 850 ac orifice tube
arr4089
Year and Model: 850 T5 1994
Post by arr4089 »
Hi All,
Ok so I recently replaced a damaged condensor on my car...Replaced all the O rings and so on. Went to get it gassed up..Ac guy said he got about 700grams of gas in it. He said he could not find the tx valve and told me its prob blocked. After research I find out 850s dont have a tx valve but an orifice or expansion valve. So I pulled the radiator resivour and ecu box. To my amazement the orifice valve is nowhere to be seen. Just the normal pipes. Any ideas..
Been thanked: 4071 times
It's in the pipe, right at the big joint in front of the timing cover on LHD, I think it's the same on RHD
arr4089
Post by arr4089 »
Should it have bolts or a flange to replace it. Mine is just a solid pipe. The volvo drawings show connectors and o rings. Mine is just a welded pipe
arr4089
Post by arr4089 »
Thinking its had a dodgy fix sometime in its life
sleddriver
Year and Model: 1998 V70 T5
Has thanked: 11 times
Been thanked: 13 times
Post by sleddriver »
It's up near the firewall in the liquid line. I don't recall any connectors in my line. On a properly running system, you can see where it is due to sudden condensation forming, at least in a humid environment. Otherwise, you can feel for the line suddently getting cold.
Not sure if Volvo ever used TXV's on 850/s/v/c/70's....my old SAAB did. Much better way to meter refrigerant IMO.
M1 10W-30 HM
arr4089
Post by arr4089 »
Ok i think i can see it. How do you replace it
Has thanked: 311 times
Been thanked: 817 times
You have to evacuate the system of refrigerant, then just open the pipe, pull it out, put in the new one. Pay attention to which end goes where.
