Clutch not engaging, brake fluid low light
aspireToRepair
Year and Model: 2009 C30
Post by aspireToRepair »
Hi guys, first time poster. Seems like a good community here, appreciate any help i'm given. Thanks!
So i've had a brake fluid light coming on once ever 2 months or so, i've been topping off with fluid and reducing brake use, gearing down more. I never have seen evidence of a leak no fluid on wheels or spots where i park. Just he other day i got in my car to go to work. Clutch basically goes to the floor, very little resistance and it doesn't come all the way back up, just a couple of inches return. Trying to leave work that day, and i can't get into gear at all. I looked under the car and the small white cylinder under the dash has fluid dripping from it, there is also fluid that has apparently beeb leaking for a while from up under the dash, not sure if it's only this little white cylinder or not. I've attached some pictures, any ideas?
