Water Pump Blades Bent Down
dlrigopoulos
Year and Model: 1996 850 Turbo
Post by dlrigopoulos »
Thoughts on what causes this
Bearing is Good[
beigg
Year and Model: 850 97
Post by beigg »
water only with no antifreeze mixed and a nice stretch of freezing temps. If that has happened, it has a great chance to allow that water to freeze. Starting the car for the first time once the water has slushed or frozen over will enable those fins to become stressed in the process.
ugh smh 850 Turbo fridge
Has thanked: 1507 times
Been thanked: 3823 times
My guess is the bearing has worn and allowed the shaft to free play and score the case
High mileage, I'm guessing, 150k plus?
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
As mentioned, worn and the tension of the belt caused it to bind or pull out and scrape the housing. The blades are not bent.
sleddriver
Year and Model: 1998 V70 T5
Has thanked: 11 times
Been thanked: 12 times
Post by sleddriver »
Wow...that is one, old WP! Also looks like it was fed a 100% diet of hard, tap water.
M1 10W-30 HM
skloon
Year and Model: 94 850 95 850 04 S60
Post by skloon »
Are you using heavy water as coolant
Been thanked: 472 times
Post by cn90 »
The blades do not look like Aisin (I may be wrong).
I suspect this is an aftermarket WP, built in a country where you can find delicious Dim-Sum...LOL.
splats
Year and Model: 1996 850 Turbo Wagon
Post by splats »
I suspect the bent blades are part of the design. But the gouged housing is due to worn bearing/bushing. I *just* had a water pump fail and it took out my timing belt: viewtopic.php?f=1&t=79764&start=10#p429710.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
cn90 wrote:The blades do not look like Aisin (I may be wrong).
Mmm.. who knows, maybe it spin some tonkinese soup
dlrigopoulos
bearing is solid no play, car is in so-cal no freezing
