Hi!
Putting my 1999 V70 Turbo AWD back together after a valve job, and I can't figure out where this wants to live! It's just around the back corner from the CPS, above the turbo (inlet seen in pic)
Thanks!
Jeff
Where does this oil line go? (Found!)
adkvolvonoob
- Year and Model: 1999 v70
Coolant banjo fitting onto the turbo case. You will need the nut
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Looks like the coolant pipe that connects on the side of the head.
You are right Robert, that's head side. I don't think I have that bracket on mine but it's been a while since I've been back thererspi wrote:Looks like the coolant pipe that connects on the side of the head.
adkvolvonoob
Yeah, that's what I'm thinking (exhaust-side of head), but I can't figure out where. It looks like it wants to lay in a certain area, and that bracket throws me farther off into the woods.rspi wrote:Looks like the coolant pipe that connects on the side of the head.
adkvolvonoob
I have 3 lines already connected, and I don't recall seeing a place for a 4th.abscate wrote:Coolant banjo fitting onto the turbo case. You will need the nut
- rspi
Contact rspi..
I believe it bends under the bracket/Cam sensor. I don't have one nearby or I'd do a pic.
There might be a picture in my CBV thread
The turbo banjo connector takes coolant off the back of the engine, so look back there.
adkvolvonoob
Found it! Thanks everyone!
It is indeed below and left of the CPS. The hose is designed to double-back more than it is to bend around the corner.
- 1633 Views
Last post by cn90
- 201 Views
Last post by vtl
- 7359 Views
Last post by rspi
- 10 Replies
- 2559 Views
Last post by SuperHerman
- 9 Replies
- 1686 Views
