850 starter makes whirring noise
- Has thanked: 2203 times
It certainly sounds like it. Have you had the battery checked recently to make sure it is good and all the connections?
Sounds like the Bendix spring is going.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Yep....Bendix.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
splats
- Year and Model: 1996 850 Turbo Wagon
I agree with the other folks. My 850 did the same thing - it starts to turn over, but then just whirrrrrrs, then maybe a clunk as the starter re-engages as it spins down. It's the clutch in the bendix gear. Replace the starter (before it knocks teeth off of your flywheel!)
If you replace it yourself, be aware that there's a bracket on the end of the starter that bolts back onto the engine block (at least on my '96 there was). This bracket was abandoned after a starter redesign, and won't fit and/or line-up with the new starter. So, if you have that old-style starter, the bracket won't fit on your new starter. I'm told that even Volvo doesn't sell the old style anymore. (Just an fyi sort of thing.)
- Year and Model: Many Volvos
- Been thanked: 76 times
I searched for just a Bendix and the only ones I could find were much more expensive than just replacing the stater motor with a rebuilt Bosch from the auto parts store. I have had to replace a couple of them but it has been a few years ago. At that time the rear support bracket fit just like the original when I installed the rebuilt part.
- 1228 Views
Last post by erikv11
- 705 Views
Last post by mhfinney
- 4345 Views
Last post by ThommyKent
- 1057 Views
Last post by RickHaleParker
- 208 Views
Last post by Blacklab467
