This.skloon wrote:They look like the lower timing belt shield bolts
P80 lower timing belt cover bolts 974674
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Ok, if these special bolts hold the timing belt guard around the bottom of the crankcase pulley then I have two standard M7 bolts left over. That may be a better option. Thanks for inputs.beigg wrote:Bingo!MrPc wrote:Those bolts look vaguely familiar..... By any chance, do you still need to install the belt guard that goes around the bottom of the crankshaft pulley? It seems to me that those bolts are similar. IIRC the long nose helps get things lined up and the threads started. (Although I still found it a kinda hard...)
- Has thanked: 311 times
- Been thanked: 817 times
The now-extra M7 bolts may be for the upper, outer plastic timing belt cover, where it screws into the cam cover.
Can someone with VIDA post the part numbe r for these please?
Teddy1975
- Year and Model: 2007 V50
- Been thanked: 7 times
VIDA says: 974674.abscate wrote:Can someone with VIDA post the part numbe r for these please?
Current: V50 2.0D, 2007, 6 speed manual
Previous: 850 2.0L N/A, 4 door 1996 manual, 740 2.3L N/A, 5 door 1992 manual, and S70 2.5T 1999 manual
- 427 Views
Last post by 850oldschool
- 462 Views
- 350 Views
- 3353 Views
Last post by SlowLane
- 1303 Views
Last post by Nevada1906
