Oil filter is doing its job.... FULL of sludge
This topic is in the MVS Volvo Repair Database » Awful, Very Bad Terrible Engine Oil Sludge
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
Could it have gotten coolant in the oil at some point?
Has thanked: 1609 times
Been thanked: 4064 times
That makes chocolate milkshake - not licorice roof tar...
:-O
dave22r
Year and Model: 2001 S60
Has thanked: 2 times
Post by dave22r »
Drove it 120 miles round trip to work. The one thing I noticed was some oil splatter on the cover. With the old oil cap it just drizzled into the head. This was a bit more pressurized. It's not an OEM cap but fits tight. Like a $8 Amazon one
So I'm just a parts replacer, not exactly a mechanic... adding everything up I'm thinking with a better seal maybe the pressure knocked something loose and that's what clogged up the filter? Meh I don't know, I'm monitoring the oil level before driving and I'll flush everything out this weekend.
Oh and abscate, I have matt's set up on my Amazon. I'll start throwing him a bone here and there; I buy enough stuff to support a 3rd world country :lol:
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Clogged PCV?
dave22r
Post by dave22r »
oragex wrote: 03 Apr 2017, 20:20Clogged PCV?
FML I hope not. I was afraid someone would say that... I guess it's a pain to replace.
dave22r
Post by dave22r »
dave22r wrote: 03 Apr 2017, 20:35
Well after a bit of research it seems to be the case. Looks like I need to block out a weekend and tear it apart. Yay.....
RigsPGT
Year and Model: Red 99 S70 T5,
Post by RigsPGT »
Where do you get your oil, Wally World? If so, get rid of it. I've had a few cars misbehave with Walmart oil and once changed with same brand and weight from an auto parts store, things normalized. Now I don't know on sludge tho as I had my customers change it right away so I can't say for sure. Was that oil refined at all? Holy sludge!
99 S70 T5, The Red Devil
Ported 19T and R manifold, 3" DP with Magnaflow race cat, 2.5" cat back, Precision FMIC, Rigs intake pipe, H&Rs, Bilsteins, 302's with Akebonos, Jewels, HIDs, egg crate grille, transmission cooler.
Thats pretty S0-Cal- for my SWMBO thats two weeks of commute mileage.
:D :D :D
Dave - if the PCV were clogged you usually get crankcase pressure, not vacuum. I would think that would help keep sludge out if it were caused by dust.
Have you done the glove test? (work glove on the crankcase breather??
jbeebo
Year and Model: S60, 2005
Been thanked: 4 times
Post by jbeebo »
If this is a naturally aspirated car, then PCV failure usually causes vacuum in the crankcase. NA cars have a different PCV system design than turbo cars. The splatter on the valve cover looks like positive pressure, but as noted positive pressure would not normally result in lots of dirt getting inside the block.
Did you check the air filter and intake piping? Wonder if dirt is getting sucked in via the intake manifold. I check and clean the air filter every time I change the oil.
2005 S60 2.4L (B5244S6), 175k miles
difflock54
Year and Model: V40 Nordic 2002
Post by difflock54 »
With that much sludge in the oil filter based on your regular oil and filter changes I would be dropping the oil pan ASAP.
It must be full of that stuff.
If that is dust or sand it must be very abrasive.
The PCV ports in the block are bound to be clogged also.
