Flashing arrow on dash
Well after calming down and looking again it was the correct PNP switch was just a pain separating the plug from the plugin block and installing the new one but I got it done and the flashing arrow is gone and the w button works as it should.The brake switch plug, however, is full of brake fluid from the leaking switch which I assume is causing the brake switch and check engine light to stay on even though when I scanned it should no engine faults.tom4342 wrote: 27 May 2017, 08:52 Well needless to say I bought the wrong switch the one in mine plugs into a harness with 3 sensors one up under the engine time for this thing to go.
Tom Hood
- Has thanked: 2200 times
Probably the ABS module failing. It throws all sorts of weird and random dash warning lights. Mine through issues with Brake/ABS/STC and on one occasion the upward flashing trans arrow.
Check with Matty at Mid-West ABS. I just fitted one of his re-built units and so far so good.
Matty has been a god-send to us on this website and probably others too. There are other places too, but the advantage he has that for a small additional charge he will ship you a unit and trust you will return yours once it has been replaced. That way you have limited downtime. He also has a how-to video on his web-site for swapping it out. He also kindly includes the E5 Torx socket on a return basis to remove the 4 screws that hold in in place on the AB pump.
- 1012 Views
Last post by Ozark Lee
- 1275 Views
Last post by jose456891
- 950 Views
Last post by iruleyounow
- 13 Replies
- 2794 Views
Last post by jtmarks923
- 1342 Views
Last post by tyrendis
