03 V70 Parking Brake - How much movement ( Answer: None) is OK? Topic is solved
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Re: 03 V70 Parking Brake - How much movement is OK?
Post by jonesg »
vtl wrote: 06 Jun 2017, 05:56
jonesg wrote: 05 Jun 2017, 23:49 As long as the rear wheels are on the ground that is true.
But his rear wheels were in the air.
What does it change?
When the wheels are off the ground you can feel the slack in the drive train.
With wheels on the ground you can't.
Botbasher
Year and Model: 98 "R" & 03 T5 V70
Been thanked: 4 times
Post by Botbasher »
abscate wrote: 06 Jun 2017, 10:10
My 98 is similar in action, so that's why I am wondering if I have an issue... or if this is just the norm?!?
Ciao!
K "unlucky in pairs?" S
You are asking here if you have issues??
:D :D :D
My 1999 and 2005 both lock up with no rotation after I apply the hand-emergency-e-parking brake FWIW.
Bring it up to ALB and we will get you setup and Ill throw in a free NY inspection - they actually have to put the car up and remove a wheel here.
Almost be worth the trip just to say HI!!! You guys and your inspections..... :lol:
Thanks!! It'll probably be next week before I can dig into it, but at least I know I'm looking for something now!
Cheers!
K "inspected" S
Never become a pessimist. A pessimist is correct oftener than an optimist, but an optimist has more fun, and neither can stop the march of events.-Heinlein
We have met the enemy and he is us.-Pogo
If speed kills, do brakes give life??
jonesg
Post by jonesg »
Botbasher wrote: 06 Jun 2017, 11:02
Cheers!
K "inspected" S
Heres the threaded ebrake adjuster thingy you were looking for. $10.
https://www.fcpeuro.com/products/volvo- ... 0-30793437
Botbasher
Post by Botbasher »
jonesg wrote: 06 Jun 2017, 12:53 Heres the threaded ebrake adjuster thingy you were looking for. $10.
Actually, more like $20.... VTL gave me that part on top of page 3, but you need this part too! https://www.fcpeuro.com/products/volvo- ... 0-30793438
Appreciate it though!!!
K "informed" S
Teddy1975
Year and Model: 2007 V50
Been thanked: 7 times
Post by Teddy1975 »
jonesg wrote: 06 Jun 2017, 10:15
Would "sort of" make sense if the V70 is rear wheel drive, which it isn't, unless it's an XC70.
There shouldn't be much movement of either rear wheel at all with the parking brake engaged, wheels on ground or in the air, certainly nothing like what KS describes is happening.
Current: V50 2.0D, 2007, 6 speed manual
Previous: 850 2.0L N/A, 4 door 1996 manual, 740 2.3L N/A, 5 door 1992 manual, and S70 2.5T 1999 manual
Botbasher
Post by Botbasher »
Teddy1975 wrote: 06 Jun 2017, 14:27 There shouldn't be much movement of either rear wheel at all with the parking brake engaged, wheels on ground or in the air, certainly nothing like what KS describes is happening.
That was my thought.... I'll grab a quick clip of it in action and quell any confusion in the gallery!!
KS
jonesg
Post by jonesg »
There is end gap movement of the brake shoes until they contact the block (part of the steel knuckle itself) that keeps them from rotating,
that translates to movement out at the tire.
Botbasher
Post by Botbasher »
jonesg wrote: 07 Jun 2017, 00:50 There is end gap movement of the brake shoes until they contact the block (part of the steel knuckle itself) that keeps them from rotating,
Jonesg... the keyword there being "gap"... what kind of gap is normal. A couple of thousandths... or a couple of tenths. That kind of difference can make for a wild ride!!
I used the transmission slop as a common example of car movement upon parking. I don't believe that parking brakes should allow a similar amount of movement and from the responses, my presumptions are correct. I would expect a little thunk, thunk from the shoes as they settle on the stops, but to get enough movement into then to sound like a dropped wrench seemed a bit excessive!
I'll open them up in a few days and see just what the heck is going on. I'll post up the findings so everyone that's chimed in can see if they won their bets!
Ciao!
KS
jonesg
Post by jonesg »
Botbasher wrote: 07 Jun 2017, 06:51
Ciao!
KS
I think the shoe end gap was about 1/8th inch, OEM vs aftermkt shoes had a slight difference in shoe backing length.
Botbasher
Post by Botbasher »
jonesg wrote: 07 Jun 2017, 12:14 I think the shoe end gap was about 1/8th inch, OEM vs aftermkt shoes had a slight difference in shoe backing length.
Dia of the wheel might make this a possibility. I'll let you know when I find out!!
KS
