When we encounter poor running or starting, a common cause is corruption in the vacuum hoses in these cars.
Commonly, these throw codes for oxygen sensor, MAF, misfire, or fuel trim out of range.
You can't just look at your hoses to rule them out, I've found again and again that you need all your senses to make sure you don't have leaks.
I had $1300 of work proposed by BMW to cure P0171 and P0174. It was clear no one was diagnosing, they were just Mossberg Mechanicing....shotgunning a ton of expensive parts.
I knocked off the induction in about one hour..it's a pain on this car
Here's is the intake bellows in installed position
Slight pressure on the idle valve bypass
P2/P80 Visual Audible Tactile Inspection of vacuum hoses VATHI
- Been thanked: 4068 times
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
Nice catch! Did they even bother to smoke it? As complicated as modern cars are, a smoke tester is necessary these days for saving time. I should have built mine 10yrs ago.
M1 10W-30 HM
M1 10W-30 HM
I built a crude one but decided I would strip it down before I bothered to smoke it. This car, the E83, is known for bad bellows so I knew to really give it the evil eye.
Here are picture details of my smoke tester
Cat litter bucket
CA sage smudge sticks
Clay
pot
Tygon (tm) tubing aka PVC tubing
Brass air fittings
Air compressor - not shown. you just need bit of air flow, you can probably blow to make this work. The side PVC hose blows right onto the smudge to make it glow, then it will puff off thick smoke.
Cat litter bucket
Clay
pot
Brass air fittings
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
Hello Steve,
Nice pics. I have almost that same meter, the 2108 not the 2108A. I have a Mastech bench meter also.
What are you measuring with it though there, i see about 64k Ohms. What is that for?
Is it hard to smoke test the system? Like where do you hook up the smoke injection hose?
A little off topic, but did you ever measure the engine cranking Amps with that meter?
That last picture sneaked in there from a AbS test procedure on the module. I haven't figured out how to test hoses by meter yet
You can tape the Tygon tube nicely to the brake booster, on the suction side of the check valve
- MrAl
Hi,
Ok thanks, i'll have to locate that next i guess
Big fat hose heading to the brake booster
- MrAl
Hi,
Thanks, i'll look for that when i go out there again.
I am assuming that smoke does not harm the system?
Does anyone use soapy water for this kind of test?
Most people will keep smoke out of the MAF by pulling off the big snorkel hose and putting a baggie over it. Thats probably smart. Any leak before the MAF doesn't matter , of course.
- 866 Views
Last post by Roljiks
- 13 Replies
- 7447 Views
Last post by Kned1977
- 881 Views
Last post by xHeart
- 10 Replies
- 3860 Views
Last post by 800artfreed
- 10 Replies
- 873 Views
Last post by erikv11
