In this photo from iPd, you can see the piece I'm talking about at the bottom of the photo, just below the O-ring. In this photo it appears to be a white plastic washer (I don't know if it's actually called a washer, but that's what I'm going to call it for now).
In my setup, looking at the other three intact injectors, as well as the pieces that broke off from the two, it appears they are reddish plastic washers (and apparently extremely flimsy).
The PCV system kit I got from iPd (https://www.ipdusa.com/products/11110/1 ... xc70-turbo) includes a set of five new O-rings for the manifold end of the injector, but does not include these washers. I don't know if that's because they don't expect them to break, or if the washer is readily available elsewhere, or if it's just not necessary.
Any thoughts on what I should do about this situation? Is this just a run of the mill nylon washer that I could pick up at a hardware store, or would I need to special order it, or, god forbid, does it only come as part of a new injector?
Thanks!
