Thinking about some options here. FCP has a Meyle power steering pump for $201 and a Maval one for $122. So, being the frugal person that I am, I'm looking over at Rockauto and there are other options here... I'm thinking about the AC/Delco. It's Professional! Or the Cardone... Any thoughts?
98 S70 N/A 5-Speed, Power Steering Pump Options
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
Retired:
2015 Volvo S60, T5, 85K
- theWIFES_S70
Woah... Autozone has a pretty affordable option. Has anyone used a Duralast power steering pump?
Retired:
Do you ever wonder how someone can disassemble, inspect, replace parts, and test a complex part for $50 ?
Let that knowledge guide you....
tryingbe
- Year and Model: None
- Been thanked: 26 times
American public by large doesn't care. Buy cheap, buy a lot, and buy often is the name of the game now.abscate wrote: 18 Aug 2017, 04:32 Do you ever wonder how someone can disassemble, inspect, replace parts, and test a complex part for $50 ?
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
- theWIFES_S70
I was watching a power steering pump rebuild video on Youtube yesterday, it certainly looks like it involves quite a bit of "finesse" work to make sure you get it right. I could certainly see the worker who has to crank out 10 of these an hour taking shortcuts. And who pays the price...
Seems like folks usually install used pumps. Do you really need a special Volvo tool and puller to take the pulley off? I can't seem to find the procedure for pulling it off without special tools.
I need to set up a flush. Trying to eliminate some random stiffness. And three "turkey-basterings" have certainly made it better, but not good enough.
Retired:
kahl
- Year and Model: 2000V70XC
- Been thanked: 10 times
2 years ago I got a power steering pump from NAPA P/N 81-1151. I had to R and R reservoir and pulley. Cost was $44.00. Pump is still working 18K miles later. I couldn't get the pulley off but the NAPa store I use has a shop. They charged me $15.00 to put on the pulley. Perfect fit. This was on a 1998 V70 AWD.
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
I've had decent luck with AC Delco products in the past as well as good luck with most NAPA parts.
- theWIFES_S70
I was thinking about that AC Delco one, too. I need to run into my local Napa and see if they have a shop that can pull that pulley off. Now I see why most folks install used pieces on here and on the internet. Does anyone have that Volvo tool? What makes it special? I'm sure there's a way to mimic its function...
Volvo 9995444 doesn't seem too terribly complex. It actually looks a lot like a bicycle bottom bracket puller tool.
For $17 plus shipping, I might just bite the bullet and get it. As long as I could lend it out at least once it'd be worth it...
https://www.volvopartsofphoenix.com/oem ... er-9995443
Retired:
- theWIFES_S70
Alright fellas, a few power steering flushes later, and some improvement, it's time to replace my pump. All this damn parallel parking in NYC! I was able to remedy some stiffness with flushes, but the groans today as I was trying to get into a tight spot were unlike anything I've ever heard before...
I don't have as much time on my hands as I used to have so I ordered a 9995443 tool in order to be able to remove the pulley with relative ease. Is there a secret to doing this? These are reverse threaded right (i.e., righty-loosey; lefty-tight), no?
Retired:
I think we can get MVS to buy that tool when done for the loaner program, but maybe it's so cheap that doesn't make sense
- 18 Replies
- 3469 Views
Last post by sventastic
- 3216 Views
Last post by volvobro
- 3155 Views
Last post by theWIFES_S70
- 1772 Views
Last post by Shift727
- 574 Views
Last post by jonesg
