2001 V70 T5 Auto transaxle problems
01_Nautic_V70
Year and Model: 2008 XC90 V8
Been thanked: 8 times
Post by 01_Nautic_V70 »
As for suppliers, here goes:
(Are direct links to merchandise allowed here?)
Amazon supplied:
Mobil 3309 ATF
Corteco axle seals for the final drive
Inline filter
ATP B-278 Transmission Filter
Genuine Volvo coolant
3/8" Fuel injection hose clamps for the inline filter
IPD supplied:
Transmission dipstick
B4 Servo Cap update kit
Transmission cooler line clips
Lower transmission (dogbone) mount
eBay supplied:
Used transmission
Florida Torque Converter supplied:
Rebuilt torque converter
Makco Transmission Parts supplied:
Friction plates C1 clutch
Steel plates B2 clutch
Bushings for planetary
Cobra Transmission supplied:
Teflon rear sealing ring kit
American Powertrain Warehouse supplied:
AW55-50SN valvebody gasket kit
Lumberyard supplied:
Custom-made bridge for lowering engine
Friends supplied:
Transmission jack
Engine hoist
01_Nautic_V70
As for pictures, here's a start from the last remove/reinstall, planning to take more this time around.
Driver's side suspension removed, ready to drop the subframe
Bridging device built for this, allows the front of engine to come up and the rear to be dropped
Transmission out and about to be opened
Internal shot with only the bellhousing removed
Bellhousing assembled and ready to go back on
Pickup magnets on the back of bellhousing splash shield, all clean
Pump assembly with 1-2 clutch pack all assembled on rear
New bushing pressed into planetary
01_Nautic_V70
One more shot of the bridge in use, this time with the engine tilted so the transmission can be pulled off through wheel well.
Bridge installed, engine tilted
01_Nautic_V70
Started the removal and install this weekend. Got a few hours in on the removal, so here are the step by step photos.
Step 1: Remove hood for ease of access
Remove hood
Remove hood
Step 2: Remove wheels and put car on jackstands
Remove wheels, place on jackstands
Step 3: Disconnect and remove battery
Remove battery
Remove battery
Step 4: Remove the airbox
Remove airbox
Remove airbox
Step 5: Remove the aluminum plate that holds the airbox
Remove airbox mounting plate
01_Nautic_V70
Step 6: Disconnect plugs at back of fuse panel
Disconnect fuse panel
Step 7: Remove fuse panel
Remove fuse panel
Remove fuse panel
Step 8: Remove strut tower brace
Step 9: Remove turbo to intercooler (over engine) tube
Remove turbo to intercooler tube
Step 10: Remove upper engine mount
01_Nautic_V70
Step 11: Remove intercooler to throttle tube
Step 12: Disconnect trans to body connectors
Step 13: Remove transmission speed sensors
Remove trans speed sensors
Step 14: Disconnect two cables at rear of transmission
Disconnect cables at rear of trans
Step 15: Remove airbox to turbo tube
01_Nautic_V70
Got a couple more hours in on the removal last night. Top end is about done, fluids drained, will work on axles next.
Step 16: Remove starter
Step 16 Starter Removed
Step 17: Remove ground wire clamp from RHS of subframe
Step 17 Remove RHS ground wire clamp
Step 18: Remove RHS oil line clamp from rear of subframe
Step 18 Remove rear oil line clamp
Step 19: Remove torque mount from front of transmission
Step 19 Remove trans front torque mount
Step 20: Remove bump stop from rear of transmission
Step 20 Remove rear trans bump stop
01_Nautic_V70
Step 21: Remove under-bumper air dam
Step 21 Remove air dam
Step 22: Drain transmission fluid through drain plug
Step 23: Drain coolant through hex socket head drain plug on LHS bottom of radiator
Step 24: Remove coolant hose from lower radiator to upper rear of engine
Step 24 Remove radiator to engine hose
Step 25: Remove transmission cooler hose from upper radiator to lower transmission
Step 25 Upper trans cooler hose removed
Step 26: Remove transmission cooler hose from lower radiator to upper transmission (Requires a 22mm or 7/8" open end wrench and crow's foot wrench)
Step 26 Trans cooler hoses removed
Step 27: Remove LHS ground wire clamp
Step 27 LHS ground wire clamp removed
01_Nautic_V70
Night 3 on trans removal, got a few hours in.
Step 28: Remove upper heater hose
Step 28 Remove upper heater hose
Step 29: Remove brake caliper and turn stop
Step 29 Remove brake caliper and turn stop
Step 30: Remove brake rotor
Step 30 Remove brake rotor
01_Nautic_V70
Step 31: Remove rotor shield
Step 31 Remove rotor shield
Step 32: Disconnect power steering rack
Step 32 Disconnect steering rack
Step 33: Remove wheel speed sensor
Step 33 Remove wheel speed sensor
Step 34: Remove upper spindle bolts
Step 34 Remove upper spindle bolts
Step 35: Remove strut
Step 35 Remove strut
