Pending p0505 IAC code 97 GLT..
I have a pending p0505 code. Idle air circuit code. I did my pcv. Everything connected right. I also did a snabb intake pipe as well as a NA Throttle Body and 960 plate. I have not adjusted the idle on it or anything though. On my boost gauge I have anywhere from 18-20 inhg at idle. About 22-24 when decel on highway. And around 16 when in drive and stopped. Doesn't seem like a leak. Runs good. Guess I could check around with some carb cleaner. I cleaned my IACV a little bit but think I didn't get all the crud out. Idle is about 950-1000. Should it be lower around 750-800? I guess I could clean the contacts on the connectors as well. It drives great now but I'm thinking maybe the TB Idle screw needs to be adjusted. Any input? Please if you need more info you can ask. Thank you!
Normal Idle on my 98 v70 t5 is 900. 750-800 is too low for my model and has a slight roughness to it chillin there (Im having IAC issue and currently have my IAC disconnected) before it faulted it sat at 900
2002 s60 Base - 215k - KIA [08-2014]
2000 s70 Base - 170k - Traded in [2015-16]
1998 v70 t5 - 232k - KIA [2016-2018]
2000 s70 Base - 180K KIA [2018-2018]
1995 850 TURBO - 77K [2019-]
- 825 Views
Last post by Duncx
- 2611 Views
Last post by shaker_chi
- 18 Replies
- 5778 Views
Last post by MadeinSweden1
- 799 Views
- 396 Views
Last post by Sveedy
