convince me it's worth fixing my headlight wipers (98 S70) Topic is solved
Has thanked: 292 times
Been thanked: 765 times
Re: convince me it's worth fixing my headlight wipers (98 S70)
I plug the washer line when I remove the wipers.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
abscate wrote: 06 Oct 2017, 23:33 Just remove one of them and then tell people one-wipered cars is a new thing.
New? They've been making these since '85!
Actually, mine has headlight wipers too...and they're broken. Surprise surprise.
Has thanked: 1497 times
Been thanked: 3810 times
I fixed mine with yellow zip ties because I ran out of pink ones -
Has thanked: 1836 times
Been thanked: 1709 times
Biggest issue with these is the overload resistor failing with time. If we could find a source of those square thick film (or whatever they are called) resistors then fixing them would be fairly easy. After so many years they need a service like most other parts of any car using grease, and a fresh amount of grease, new resistor and off they go again. Most of us would only have to do the job once in the cars' lifetime (or is that our lifetime?). I use the copper wire replacement, but need to look again at the in-line fuse to prevent blowing the main fuse which takes the main wipers out and some other stuff.
If you don't need them as the headlights don't get too bad when driving year around I wouldn't bother. Here in winter they are handy to have in snow and dirty roads we get, but even I have doubts on their use.
utilityaudio
Year and Model: '98 S70 GLT
Has thanked: 36 times
Post by utilityaudio »
Thanks everyone, sounds like a pretty unanimous chorus of "don't bother"
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
Ceramic/Sand resistors?
Like these? https://www.allelectronics.com/item/2.5 ... tor/1.html?
