I am going to replace my 1995 855 non-turbo gas cap. I just get one from dealer but it is different - a plastic/rubber "string" attached to the cap. My original has no "string" attached and has a plastic "hook" in the bottom of the cap. New one has no "hook" at all. Where should I tide the "string" within the gas cap compartment ?
Thanks,
Ching-Ho Cheng
1995 855 Gas Cap replacement
- gmh
- Year and Model: 2016 XC60 T5
- Has thanked: 28 times
- Been thanked: 22 times
It is usually tethered to the fuel door on the later models. Find a place to attach with a zip tie.
- pg65a.jpg (27.48 KiB) Viewed 2243 times
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-2025) sold to Matthew
2014 XC60 T6 (2017-present)
2016 XC60 T5 (2024-present)
1969 145S (1987-91)
1973 145E (1989-90)
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I bought one of those newer style caps too. I used the upper door hinge screw to attach the tether.
Later on, I found an original hook-style cap in great condition at the junkyard, so I removed the newer style cap and tether and switched back to the old style.
- Has thanked: 2207 times
Are the lid screws long enough for the mounting point to be fitted under one? Might make the lid a bit wonky though.
Neil
Neil
- jreed
I was worried about that too. When I tried it on the upper hinge screw, it fit fine.
- 9 Replies
- 3112 Views
- 680 Views
Last post by CSDentonTX
- 9 Replies
- 2221 Views
- 10 Replies
- 1562 Views
Last post by 454cid
- 779 Views
Last post by deepsouth
