Small Transmission Service Project Topic is solved
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Re: Small Transmission Service Project
Post by kallekula »
And the results are in...
Hard downshifting significantly reduced. However, I now have a delayed drive engagement :?
My guess is that I didn't calibrate/measure the SLT solenoid properly. Gonna buy a valve body cover at the bone yard and drill holes into it so I can easily adjust the solenoids.
BMW 540i 2002
S70 Base 2000
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Yeah that sounds like a pressure issue. You solved that on the S70 in the same way. Best of luck Kallekula!
kallekula
Post by kallekula »
Ok, somehow I screwed up the solenoids AGAIN. Hooked up the pressure gauge and there is just no way to get a stable pressure around 5-10 psi on idle in park. I can adjust it to that but after shifting it goes up or down when in park again. Off to the boneyard for a new set of solenoids. Gonna take it a little bit easier with the reamer this time. To be continued...
BMW 540i 2002
S70 Base 2000
kallekula
Post by kallekula »
Got a set of new solenoids from the junk yard. Took it really gentle while cleaning them this time. Had to adjust the SLT 6 clicks (1/2 turn) clockwise to get P->D to engage smoothly. Driveway is covered in transmission fluid but it shifts fine now 😀
BMW 540i 2002
S70 Base 2000
Well done Kallekula. Lesser people would have faltered.
