Just an UPDATE,
Last lubed the blower motor Dec 2014 with 2 drops of oil on each end.
Two years later, it squeals again on cold morning.
So I just lubed it again.
This is my own experience, the lubing tricks lasts about 2 years.
Climate unit blower replacement
configsys
- Year and Model: V70R
- Has thanked: 2 times
- Been thanked: 5 times
My blower on my 2000 V70R died yesterday after emitting a moaning sound for the past few weeks. Took it apart, sprayed it clean and it worked but didn't seem to be at full strength as it once was so I decided to go to the junkyard and search for a replacement. Lucked out as there was a same year S70. Purchased the resistor pack and blower. I sprayed the blower with contact cleaner before I installed it and lo and behold, it blows stronger than my original one!
On a side note, both units were the original Volvo parts but the blower motors were both Delco.
Thanks to all who contributed to this thread.
'16 S60 AWD
'17 S60 (totaled)
'13 XC60 Polestar
'12 S60 T5
'04 XC90 (sold)
'02 S40
'00 V70R
'93 850 GLT (sold)
'13A DICE/VIDA
'17 S60 (totaled)
'13 XC60 Polestar
'12 S60 T5
'04 XC90 (sold)
'02 S40
'00 V70R
'93 850 GLT (sold)
'13A DICE/VIDA
rsmigel
- Year and Model: 1994 850 Turbo
- Been thanked: 2 times
Great thread... read all 14 pages.
I'll be replacing my bad Power Pack (I hope it's not the ECC head unit) and blower motor with a new FCP Bosch unit (motor is running fine and quiet but it is 24 yrs old) as my air flow has degraded slowly over the past year to where it is 10-20% of original. Also will add a new cabin air filter and housing on my '94 850T wagon that never had one. Nothing but the best for Wifey!
And only 180K miles...
- Has thanked: 2210 times
If you have ECC, have you cleaned the cabin temperature sensors in the headlining behind the front door grab rails above both front doors?
They get choked with airborne crap and then the system cannot sense correctly and will reduce the effectiveness of what the system will give in terms of output.
- 1372 Views
Last post by Jepc
- 2496 Views
Last post by DrDan
- 2212 Views
Last post by Jumbobazman
- 2594 Views
Last post by nsomlai
- 1154 Views
