I believe the lighting went out once before, hit a bump and it came back on. So I'm assuming there is a loose connection somewhere. Tried to do a search for this, but all I turned up was replacing bulbs. I don't think I killed the bulbs in the incident, but maybe. I find it curios that power on the left and right sides would be separate. I have not pulled the stereo yet, as I was unsure of how temperamental the anti-theft system was. Any tips on where to hit it
Stereo Lighting Half Out
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
So quick story, I was driving the other day hauling skis. I had to slam on the breaks, resulting in the skis flying forward and slamming into the stereo. Everything seemed good. Last night I went out for a drive, turned my lights on, and noticed the entire right side of the stereo and climate control illumination was out. Hit it in a few places and got the climate control to light back up, but most of the stereo is still out (pic).
or what to look for?
Knows enough to be dangerous
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
New bulbs.
- Has thanked: 2211 times
Somewhere on MVS there is a how-to on replacing the bulbs. One may have been dislodged or have a broken filament. Might as well replace the lot while in there. The tricky one is the one for the LCD display as it requires soldering if I recall and having to desolder the display to access the bulb. That one is working so no worries.
- WhatAmIDoing
Alright, new bulbs it is. Anyone got a source for those? Guess I'll also do the aux jack mod while I'm at it.
DeathRex
- Year and Model: 1996 850 Turbo
You might have cracked the circuit board, or broken a couple of bulbs. There are 3 - 2.2Ohm resistors that supply power to 1 or 2 bulbs each. The resistor on the upper right got burnt up. Best to check the bulbs with a multimeter, should be under 20 ohms each.
You'll have to check the back of the PCB to see if you have a cracked circuit board. It can be fixed, but it isn't that easy.
- 815-1.jpg (63.42 KiB) Viewed 2187 times
- 815-2.jpg (78.52 KiB) Viewed 2187 times
- rspi
Contact rspi..
- rspi
Contact rspi..
- rspi
Contact rspi..
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
It's a very easy repair unless the board cracked. If it did, I would suggest running jumper wires to allow for flex in that area again...
2023 Lexus RZ450e -66k
- Been thanked: 504 times
The DIY below has Radio Shack bulb info.
Since Radio Shack is closed, you can find equivalent on ebay, just buy a pack of 10 bulbs on ebay for cheap:
viewtopic.php?t=7132&start=70
IIRC, then these are T1 bulbs 12V 50 mA type.
Check Amazon review:
https://www.amazon.com/dp/B00L8BR76A
- 9738 Views
Last post by zoli440
- 750 Views
Last post by sandyegg
- 798 Views
Last post by difflock54
- 1687 Views
Last post by heatherw
- 18 Replies
- 5064 Views
Last post by Teddy1975
