Hi Everyone.
Its been a while since I had to post anything.
I hope someone can help me figure out if the Drive Shaft Center Bearing for my 02 V70 XC AWD AUTO is replaceable.
Im having a hard time finding information on replacing the
Center Carrier Bearing for my year and model.
Any help will be greatly appreciated.
Thanks
Jay
Drive Shaft Center Bearing for my 02 V70 XC - replaceable?
Driveshaft center bearing -- 2002 V70 XC -- replaceable?
- Been thanked: 504 times
This is generic principle whether it is Volvo or BMW...
1. Mark the 2 halves BEFORE disassembly, otherwise you WILL have vibration!
2. The old carrier bearing: you can tap it out or use Angle Grinder (wear goggles!).
3. The press the new bearing in:
- Machine shop is best.
- If no machine shop, then cut the old bearing INNER race as 2 halves, then wrap around the new bearing using a screw-clamp. Now tap on the old inner race using a drift, work slowly until it goes in.
You tube has some videos.
PS: Your problem is how to find quality German-made bearing. Most of th bearings sold are Hamburg-Technic with Chinese bearing, which may be OK as this bearing does not do much other than supporting the weight of the DS.
- SuperHerman
- Been thanked: 207 times
Expanding on what cn90 stated in #3 - you can use the old inner race or something of similar diameter to push down on the inner race (not on the outside) and use a long hollow tube that sits on the old inner race and tap on that as it seats. You can also use a press with said set up.
For #2 the old bearing from what I have read gets seized onto the prop shaft and some time the only way to remove it is to cut it off with a grinder - outside first, then remove bearings, then inside. You may have to cut at an angle so you don't cut into the prop shaft. When you get close hit it with a chisel and it should crack rather than grind all the way down.
It would be great if you post your year and model with pictures of the process as this question has been popping up rather often.
mrjay62
- Year and Model: V70XC 2002
- Been thanked: 3 times
Thanks superHerman.
2002 volvo V70 XC AWD 2.5L AUTO.
I sprayed everything down we penetrating oil tomorrow I hope to remove the shaft and I'll take pictures and post them. I did find bearings made in Japan so far no luck on anything made in Germany other than to buy it from Volvo thank you guys
- Been thanked: 4064 times
You can get a good used one form the guys in Utica, just East of You. I frequently drive through that area too if you are tight on dough and want to squeeze shipping costs out.
mrjay62
Thanks abscate.
It's not a question of funds, I like to try and repair this if I can myself.
If I fail then I'll take another route.
Do you have a name for this place in Utica?
Thanks again...
Thanks again...
mrjay62
Thank you abscate.
Update. Center bearing is completely rusted away. It's rotted right off the bracket. NYS salt! Grrrr
I got all the bolts out and the Axle has been soaking in PB Blaster. For 2 days tapped all around it Heated it , So far its not budging. This morning im going to try my acetylene torch maybe more heat will do the trick.
- 10 Replies
- 3125 Views
Last post by carboncow
- 5184 Views
Last post by SuperHerman
- 193 Views
Last post by guga
- 2876 Views
Last post by Rattnalle
- 549 Views
Last post by wanderdüne
