Have replaced all sensors, timing, still brings up this code, would the computer by any chance cause this
2004 c70 2.4 turbo as I don't believe signal to variable timing solenoid is being sent
P0016 code
- RickHaleParker
- Been thanked: 980 times
What is the condition of the oil?
284: ECM-643A (P0016) Camshaft position, exhaust. Signal too low or too high.
Diagnostic trouble code (DTC) information
D2102380 Condition
The control module checks that the camshaft is in the correct position in relation to the position of the crankshaft. If the position of the camshaft is incorrect, the control module will adjust the adaptation for the camshaft. Diagnostic trouble code (DTC) ECM-643A or ECM-644A is stored if the adaptation becomes too great.
Substitute value
None.
Possible source
Signal too high
Malfunction indicator lamp (MIL) lit.
D2102380 Condition
Substitute value
None.
Possible source
Signal too high
- Poor oil quality
Incorrectly adjusted camshafts
The timing gear belt has jumped off the cogs
Defective reset valve
Mechanical fault in the variable valve timing (VVT) unit.
- Poor oil quality
The timing gear belt has jumped off the cogs.
Active
Past
Past
steveatlast13
- Year and Model: 2004 C70
It s new oil, change regularly, I might need to check oil pressure. It's been a whirlwind trying to correct this last problem. Thanks
Too bad I don't make the $$$ to take it to a Volvo mechanic
- Year and Model: Many Volvos
- Been thanked: 76 times
When you replaced the timing belt did you set the CVVT preload? That code is usually due to the CVVT preload not being properly set, particularly if it post immediately when you start the engine.
steveatlast13
Mechanic said he did, car cranks up and no trouble code till u shut it off and crank it back up, Ck eng lite comes on. I drove it over an hour for I shut it off and crank it back up, code pops
- RickHaleParker
Adaptation to great, not Adaption not working. Something is a little off.Diagnostic trouble code (DTC) ECM-643A or ECM-644A is stored if the adaptation becomes too great.
Active
Past
Past
- Has thanked: 1611 times
- Been thanked: 4075 times
Mechanic screwed up the timing marks. You can check in driveway by removing cover and turning engine over by hand too.no damage done, just needs to be moved by 1 or 2 teeth
- RickHaleParker
I'm thinking the Mechanic failed to align the VVT to the exhaust camshaft correctly.
OP this is what a correctly aligned VVT looks like ... exhaust one clog off when at resting at upper limit.
"Installing the timing gear pulley for the camshafts
A2101348 Timing gear pulleys with variable valve timing unit
Check that the screws holding the timing gear pulley to the variable valve timing unit have been slackened off.
Press the variable valve timing unit and timing gear pulley onto the camshaft.
Install the centre screw which secures the variable valve timing unit to the camshaft. Do not tighten.
Position the upper timing cover.
Turn the timing gear pulley clockwise until the screws at the oval holes are in their respective limit positions.
Hold the variable valve timing unit. Turn clockwise until the timing gear pulley marking is 1 cog before the marking on the upper timing cover.
Check that the timing gear pulley is still in the limit position in the oval holes.
Tighten the centre screw for the variable valve timing (VVT) unit. Tighten to 120 Nm.
Note! Check that the VVT unit does not rotate when tightening. "
A Volvo Camshaft/Crankshaft alignment kit comes in handy because, you can get the Camshafts and Crankshaft aligned independent of the timing marks. From there it just the matter of getting the VVT and timing gears aligned to the camshafts.
Volvo Camshaft/Crankshaft alignment kits are $45.00+ depending on source. For the amount of time and frustration the kit can enable one to advoid, they are worth the investment.
Active
Past
Past
WARNING WARNING WARNING
If you get a cheap cam lock tool, do not overtighten the bolts in the cams - NO NEED FOR TOOLS
If you snap these off in the cams, it bites the big one.
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
As in, Hand tighten only?abscate wrote: 11 Apr 2018, 12:13 WARNING WARNING WARNING
Current Volvos:
- 10 Replies
- 6318 Views
Last post by Mike Langlois
- 1889 Views
Last post by Tundra12
- 648 Views
Last post by jonesg
- 973 Views
Last post by drscottsmith
- 25 Replies
- 12434 Views
Last post by jmartin919
