Ecm-9150 Will a contactless sensor solve this?
I've been getting an error code, ecm 9150, which indicates problem with potentiometer 1 in the etm. On my last car thir erro came during driving. But here it comes when you turn the ignition on. First I thought it was intermittent. But if I clear the code it comes back the third time I turn the key. Always. That indicates to med that the problem is there all the time but the error code shows after three drive cycles. The question now is what the probability is that a new contactless sensor wil solve this. Or is it more likely that there is another problem inside the etm or with the wiring? What do you think?
Have the same problem:(soccer wrote: 12 Apr 2017, 02:07 I've the same problem an error code, ecm 9150 . The car work well . But the error code shows after three drive cycles.
As I well understand, you have found a solution. What does mean "intermittent" ??
Any solution?
Thanks
