Hi guys,
Can anyone help me out figuring out the issue?
The car has 144k KM, Timing belt done 3 years ago. Its a 6 speed manual.
[youtube][/youtube]
Volvo v70R 2003 wont start
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
The crank speeds way too fast, much like when there's not spark plugs installed. Is it your car? Did the engine shut off all of a sudden? As above, it feels like the timing belt snapped (can happen with cheap timing belt parts) and the cam doesn't follow the crank causing no compression. Just undo the two torx screws on the upper engine cover, then release two clips and lift the cover.
Yup, no compression. The timing belt was loose and probably skipped 3 or 4 teeth. The engine is damaged, we will remove the head and see whats to be done.
Thanks
Thanks
Volvo 850 1995 T5-R 2Litre 210HP "420.000KM"
Volvo V70 2002 D5 "315.000KM"
Volvo V70 2003 R "144.000KM" (Coming Soon)
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
There may or may not be engine damage, depending on how far the belt slipped. Before you pull the head off you might want to borescope the cylinders to see if there has been any valve contact on the piston crowns. Maybe try looking at the belt, tensioner, idler, etc and see just how far off things are.
The pistons have marks on them even if the valves have not touched, so don’t pull that head. Reset the timing belt To the marks and check compression.
- oragex
Don't forget to replace the PCV while there
chrism
Judging from the photo, it looks like the head is already off. So now what, fill the combustion chambers with solvent and see how fast they drain through the valves?abscate wrote: 13 Jul 2018, 03:16 The pistons have marks on them even if the valves have not touched, so don’t pull that head. Reset the timing belt To the marks and check compression.
IF the heads are off, just do the valve and seal job.
It really does pay to do the compression test while it still together though.
- 1211 Views
Last post by whtwgn
- 996 Views
Last post by jimmy57
- 489 Views
Last post by teachme
- 25 Replies
- 8682 Views
Last post by AmericanT4
- 1101 Views
Last post by V70RR
