PVC issue after battery change
My 6 year old Volvo battery finally gave out. Jumped the battery to get the car to the shop. Shop replaced with an Interstate battery. Picked up the car and went back to the shop within 5 minutes because of a high pitched noise. Told it was a PVC issue (there was no noise when I drove to the shop on the jumped battery). Any thoughts on PVC issues after a battery change? Also, when neighbor jumped the Volvo battery, he originally hooked the battery cables up wrong (smoke from the battery), not sure if that’s relevant. Thanks.
Yuck.. I would guess alternator diodes might be fried.
If you bang the brake ejector pump (vacuum for brakes ) moving batteries around , that could whine too.
Track down the noise source with a hose in your ear.
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
With the battery in the back its hard to bang other stuff.abscate wrote: 15 Jul 2018, 11:22 Yuck.. I would guess alternator diodes might be fried.
- Rattnalle
Dip stick sounds like the PCV. That can't possibly be affected by the battery.BKR wrote: 15 Jul 2018, 11:47 Wow, thanks for the quick feedback. The shop told me to (until I can get to the dealership) pull out the oil dipstick.....when this is done, the noise disappears.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
If the high pitching sound is from the PCV then pull the dipstick or untwist the oil cap and the sound will go away.
What gets my attention is when you say your 6 years old battery was completely flat. Don't blame it right away on the battery. It may very well be an issue with a parasitic drain or the alternator. Any good shop should have first tested the alternator. With a new battery, if the battery is fully charged (should be so most of the time when driving) the alternator will show some 13.7v. If the battery is a bit discharged, the alternator will show some 14.5v. You may try to discharge a bit the battery (radio on, headlights on for 10 minutes with the engine on), then fire up the engine and read the alternator.
Also see this topic viewtopic.php?f=9&t=85966
- 1963 Views
Last post by alschnertz
- 1670 Views
Last post by E Showell
- 14 Replies
- 2312 Views
Last post by 30CSI
- 771 Views
Last post by Ben850
- 2804 Views
Last post by FLXC90
