I did a search, and it came up with too many solutions for too many models, so, new thread.
Work with me, guys!
98 V70 non-turbo. Car has run flawlessly up until now. Drove car about five miles and parked it. When I came out, it would fire but acted as if it was running on two cylinders and died. Did this about four times, then just spins on starter with no ignition at all. Took cap off of fuel rail and pushed release valve in. No pressure and no fuel came out. All fuses good.
Suspect 1: Fuel pump relay. Starting to identify which one that is. Can you point me right to it? Is there another relay you can swap in? I may have a spare one kicking around.
Suspect 2: Bad fuel pump. I'm not there yet.
In general car is very well cared for. Clean under the hood and many new parts. I've had it for the past year. 154k miles.
1998 V70 will not start - apparently no fuel.
- Eddystone
- Year and Model: 1967 Ford GT40 Mk IV
- Has thanked: 63 times
- Been thanked: 81 times
All U.S. market models.
All running and on the road.
- Has thanked: 1611 times
- Been thanked: 4074 times
- Eddystone
Thank you @abscate ! Found the info where you led me, tested with paper clip. Engine starts right up. I'm skilled at replacing electronic components and soldering, but Radio Shack is no more. I have lots of capacitors around but I don't hold out much hope of finding and identifying the right ones.
There is a great pick n pull in Allentown where you can get two spare 103s for NTN.
Don’t buy the aftermarket cheapie....it croaks an early death
- Eddystone
I ended up buying one of these to get back on the road:
Intermotor Fuel Injection Relay Part # R6024
They had it in stock at Advance Auto parts priced at $52 and I got it for $42. I'm going to order the capacitors for the Volvo part and probably swap it back in. The original was clean as a whistle inside with no evidence of problems with the caps (no leakage), but it didn't work!
Now I have to look for the evaporative emissions leak. I looked at the line that goes past the fuel filter. It seemed spongy but intact. I need to get that fixed to pass inspection.
- Year and Model: Many Volvos
- Been thanked: 76 times
The capacitors are 22 uF and 100 uF electrolytics (one each). 25 Volt or greater but you have to watch the diameter on the higher voltage ratings.
Any good electronics supply house should have them if you have one locally. You can always get them through places like Digikey or Mouser but the freight eats you alive.
- Eddystone
I live just outside of Philadelphia, and all of the electronic supply houses seem to be gone.Ozark Lee wrote: 20 Jul 2018, 18:51 You can always get them through places like Digikey or Mouser but the freight eats you alive.
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
Try amazon...
2023 Lexus RZ450e -66k
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I had good luck buying the fuel pump relay capacitors from DigiKey. For small orders they will ship good old USPS for a reasonable price (I think it was $2 or $3 for postage).
When I replaced my capacitors, I also noticed that the solder joint between the circuit board and one of the relay pins was cracked. You might want to inspect yours for this type of damage and repair if needed.
- 1104 Views
Last post by jonesg
- 2638 Views
Last post by Chuck W
- 2188 Views
- 849 Views
Last post by jmartin919
- 13 Replies
- 3393 Views
Last post by loosenut
