Adding front license plate frame to 850
This topic is in the MVS Volvo Repair Database » Which Brand Battery To Buy?
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Re: Adding front license plate frame to 850
Post by jblackburn »
I got one for like $15 from FCP Groton; I just changed to Virginia plates and needed to add one to the front. They'll have it shipped out the same day, and mine got here within 2.
'98 S70 T5
2016 Chevy Cruze Premier
Murdoc79RC
Year and Model: 1998 V70R
Post by Murdoc79RC »
BEJinFbk wrote: 24 Feb 2011, 12:01 You can get rubber "well nuts" and the bolts to go with them at most hardware stores in the fastener aisle.
There's a brass threaded insert at the far end of the fastener that compress's the rubber.
Drill the holes, insert the well nuts, attach the bracket and snug'em down.
I know this is an ooold post, but for the record I wanted to share a lil info to help future generations,
BEJinFbk's recommendation worked perfectly, except I grabbed the wrong size hardware the first time I tried.
In my case, on a '98 V70, the original mount and hardware was long gone, and there were no traces of a threaded nut or anything left in the bumper - just two holes. Ordered the mount from FCP euro, then went to hardware store to find the "well nuts"/"expansion nuts". Lowes had them in the specialty hardware drawers.
I found well nuts that accept a #10-24 screw to be the perfect diameter, and picked up #10-24x3/4" stainless steel pan head machine screws to go with them. Worked perfectly.
New owner of a 98 Volvo V70R, be patient with me, eh? I'm learning.
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
There's an even simpler and more secure way. Use high grade double sided tape. The kind approved for mounting stuff to walls. Much cleaner look and less work too.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
US plates are a bit different. Volvo provides a bracket to retain the
taller ones that we have here. The well nuts are for attaching the frame,
not the license plate.
Rattnalle
Post by Rattnalle »
BEJinFbk wrote: 25 Jul 2018, 01:29 US plates are a bit different. Volvo provides a bracket to retain the
I know yours are smaller but slightly taller. I don't see that making adhesive not work though. As long as the plate is pliable enough to follow the contours of the car.
Has thanked: 1504 times
Been thanked: 3817 times
Ive got my from zip tied on, seeing the bracket is only 12 bucks at FCP I should replace it
It’s about a $200ticket in my town if it falls off and it’s is enforced
