98 S70 GLT Key Spin
About two weeks ago my key started spinning in the ignition. I searched the site and as usual, it seems to be a fairly common problem. I went to the stealership and ordered the mechanical portion of the ignition. The spinning got so bad, I was almost stranded a couple times. I sprayed some WD-40 in where you would insert the key and since then (about 50 start cycles) I haven't had the key spin at all. I'm going to install the mechanical part of the ignition in any case, but is my problem more likely the electrical portion and the WD-40 just cleaned it up a little bit? Anyone experience something similar?
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
Your ignition switch is worn out. The only real solution is to switch it out.
- 1154 Views
- 1605 Views
Last post by darylrobert
- 918 Views
Last post by greg850r
- 23 Replies
- 10675 Views
Last post by zupta82
- 1500 Views
Last post by zimbodel
