Cruise Control Intermittently working-- stumped
Has thanked: 1507 times
Been thanked: 3825 times
Re: Cruise Control Intermittently working-- stumped
Remember if you lose traction , even briefly, cc will shut off. The bump might be causing that
Has thanked: 293 times
Been thanked: 766 times
WhatAmIDoing wrote: 30 Sep 2018, 00:29 The vacuum lines are a pretty good bet and cheap to replace. The switches for the clutch and brake are also an easy place to start. I don't know if there is any record of the CC pump or relay ever going bad, but those should be easy to test. Also should check the fuse for CC. Some users have reported the wiring for CC failing in the turn signal lever.
Edit:
JimBee wrote: 29 Sep 2018, 20:13 I just found the link you need to troubleshoot all the parts of the cruise system. I'll be using it too. Read down the thread, erik posted the link:
viewtopic.php?f=1&t=65680
This is a good guide. Does anyone know if there are difference for CC between a 95-96 and a 98?
There are zero differences between 95-96-97-98 CC setups.
(1) Check the rotting vacuum lines, that's usually the problem. Don't forget the hard plastic line to the firewall.
(2) If you're still stumped, realize you should have just used the troubleshooting guide, it is easy to follow and works. :D
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
viper69
Year and Model: 850GLT 1995
Has thanked: 70 times
Post by viper69 »
I heard it could also be ABS sensor related, some time of speed sensor if I recall properly.
Volvo 850 GLT 1995
5 Speed Manual transmission
122,500 miles and barely broken in
'82 Volvo DL Wagon, 4 speed manual
'77 Saab 99 EMS, 4 speed manual
