Dust cover for headlight housing
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Link to the bulbs? I'm interested.speedyt5 wrote: 29 Oct 2018, 18:24 Welp, just tried the HID’s... glare everywhere. Have to stick to the LED’s I got... now to drill a hole in the housing or not![]()
Also, the backs of the LEDs do get pretty hot, though I'm not sure if it's enough to melt the covers or not. That being said, without some airflow, those bulbs may die pretty quickly.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- Clemens
- Has thanked: 500 times
- Been thanked: 228 times
The C70 clear glass won´t fit the 850ies. Could I use those Morimoto units with the stock glass of the 850/V70 series or would theis create a bad light pattern?
P.S. Sorry for hijacking this thread.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
FlyingVolvo
Clemens wrote: 30 Oct 2018, 01:22The C70 clear glass won´t fit the 850ies. Could I use those Morimoto units with the stock glass of the 850/V70 series or would theis create a bad light pattern?
It won't work as well if it's the fluted lens. Here's a writeup from a member on how they did their projector retrofit (almost exactly as mine) but used some tools to sand down and create a clear spot for the projectors on the stock lens.
viewtopic.php?t=79631
2023 V60 T8 PE
2023 V60 T8 PE
speedyt5
- Year and Model: s70 t5, 1999
- Been thanked: 2 times
ecbsykes wrote: 29 Oct 2018, 20:39Link to the bulbs? I'm interested.speedyt5 wrote: 29 Oct 2018, 18:24 Welp, just tried the HID’s... glare everywhere. Have to stick to the LED’s I got... now to drill a hole in the housing or not![]()
Go to amazon and they are the Beamtech H7’s... I had some LasFit that just scattered light everywhere. These beamtechs are awesome.
speedyt5
Welp, I went to open the hood today and was going to drill a vent hole in the dust cover however I noticed on the right hand side there were watermarks - probably from a huge puddle I drove through, meaning that water can absolutely get to the back of the led if I drill a hole in it. It was only a couple drops but I don’t know what a couple drops could do to the back of an LED. I have decided to not drill a hole in the covers but the back of these LEDs get extremely hot, is there any danger to have them basically touching the dust cover and it generate so much heat in there? I guess the bulb could fail but I’m thinking more along the lines of melted plastic in the headlight housing?
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
FMVSS violation - not sure what the fine is. Get an officer on a bad day and these retrofits can become extremely expensive.
2023 Lexus RZ450e -66k
FlyingVolvo
The heat will likely cause premature failure. Could be weeks, could be years though, who knows. You could just try it and check it after increasingly longer intervals and see how it does.speedyt5 wrote: 30 Oct 2018, 17:53 Welp, I went to open the hood today and was going to drill a vent hole in the dust cover however I noticed on the right hand side there were watermarks - probably from a huge puddle I drove through, meaning that water can absolutely get to the back of the led if I drill a hole in it. It was only a couple drops but I don’t know what a couple drops could do to the back of an LED. I have decided to not drill a hole in the covers but the back of these LEDs get extremely hot, is there any danger to have them basically touching the dust cover and it generate so much heat in there? I guess the bulb could fail but I’m thinking more along the lines of melted plastic in the headlight housing?
2023 V60 T8 PE
2023 V60 T8 PE
speedyt5
Yes I think I’ll leave it be for now, thank you all.ecbsykes wrote: 30 Oct 2018, 18:58The heat will likely cause premature failure. Could be weeks, could be years though, who knows. You could just try it and check it after increasingly longer intervals and see how it does.speedyt5 wrote: 30 Oct 2018, 17:53 Welp, I went to open the hood today and was going to drill a vent hole in the dust cover however I noticed on the right hand side there were watermarks - probably from a huge puddle I drove through, meaning that water can absolutely get to the back of the led if I drill a hole in it. It was only a couple drops but I don’t know what a couple drops could do to the back of an LED. I have decided to not drill a hole in the covers but the back of these LEDs get extremely hot, is there any danger to have them basically touching the dust cover and it generate so much heat in there? I guess the bulb could fail but I’m thinking more along the lines of melted plastic in the headlight housing?
- 653 Views
Last post by SuperHerman
- 1413 Views
- 1612 Views
Last post by sidpink
- 5182 Views
Last post by AVOIT17
- 14 Replies
- 3896 Views
Last post by instarx
