I have a 1998 V70 and the front ball joints on the control arms keep failing. Is it cheap part or can I have some sort of underlying issue ?
Thanks,
Paul
1998 V70 AWD what would cause control arm ball joint to keep failing
- Has thanked: 1614 times
- Been thanked: 4078 times
If you arent using Lemforders or OEM for the control arms/ball joints, they will fail each year.
- Has thanked: 2215 times
- Been thanked: 1853 times
I had a set of aftermarket control arms fail in less than 6 months. Since then OEM or Lemforder only.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
TRW is good,Moog (Federal Mogul),Febi,Meyle HD(not regular Meyle).
Lemfoder is the best since it's OEM...all others from above are following.
Just stay away from ProParts Sweden!
What brand did you used previously?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Trw and other brands i mentioned in previous post should last for a while.
If your control arms have just bushings failed...they are replaceable and they are pretty cheap.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
AWD?misha wrote: 02 Nov 2018, 02:59 Trw and other brands i mentioned in previous post should last for a while.
- 9 Replies
- 7211 Views
Last post by BrianV70
- 10 Replies
- 4769 Views
Last post by oragex
- 15 Replies
- 3765 Views
- 4224 Views
Last post by Tonyx
- 12 Replies
- 5682 Views
Last post by darrylrobert
