1998 V70 AWD what would cause control arm ball joint to keep failing
Miltown
Year and Model: 1998 V70
Post by Miltown »
I have a 1998 V70 and the front ball joints on the control arms keep failing. Is it cheap part or can I have some sort of underlying issue ?
Thanks,
Paul
paul
'98 V70 awd
'83 BMW R80RT
Has thanked: 1609 times
Been thanked: 4065 times
If you arent using Lemforders or OEM for the control arms/ball joints, they will fail each year.
Miltown
Post by Miltown »
That’s what they are doing .
paul
'98 V70 awd
'83 BMW R80RT
Has thanked: 2199 times
Been thanked: 1851 times
I had a set of aftermarket control arms fail in less than 6 months. Since then OEM or Lemforder only.
Miltown
Post by Miltown »
How about TRW ?
Paul
paul
'98 V70 awd
'83 BMW R80RT
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
TRW is good,Moog (Federal Mogul),Febi,Meyle HD(not regular Meyle).
Lemfoder is the best since it's OEM...all others from above are following.
Just stay away from ProParts Sweden!
What brand did you used previously?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Miltown
Post by Miltown »
I think ProParts Sweden 1st Ha , then TRW.
paul
'98 V70 awd
'83 BMW R80RT
misha
Post by misha »
Trw and other brands i mentioned in previous post should last for a while.
If your control arms have just bushings failed...they are replaceable and they are pretty cheap.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Miltown
Post by Miltown »
Cool that’s interesting .
paul
'98 V70 awd
'83 BMW R80RT
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
misha wrote: 02 Nov 2018, 02:59 Trw and other brands i mentioned in previous post should last for a while.
AWD?
