Ocelot
Year and Model: 1998, S70
Has thanked: 61 times
Been thanked: 17 times
Post by Ocelot »
jvl wrote: 20 Nov 2018, 09:28
WhatAmIDoing wrote: 20 Nov 2018, 07:40
Ocelot wrote: 20 Nov 2018, 05:52 Wow, that looks like some serious work man! Nicely done! Can you - or anyone on this forum - help me out with a question about audio in my S70? Here's the thing. The speakers in the car work fine, I think quality of the sound is just perfect. But, I miss some bass in the sound but... I don't see me installing a big subwoofer and amplifier in the trunk of the car. Is there some... midway? Like a small subwoofer and amplifier in one device that I don't know about?
You can replace the subs mounted in the back shelf behind the rear seat. Though I have a T5, and I don't know if all models had rear subs? The stock subs are great if you have the stock amplifier under the passenger seat and it still works.
Ocelot,
I have this sub mounted under my passenger seat, cost effective and sounds great (it did take me a while to get the settings straight though):
https://www.pijlaudio.nl/INPHASE-USW8
This shop is in Amersfoort but also ships. I dropped by because I wanted to check the size and the guy was really nice and helpful.
Message me if you want to get more details?
Joost
Thanks Jvl! I've send you a private message for more info! 8)
'Hij die zonder zonde is, werpe de eerste steen. Ik buk wel'. Simon Carmiggelt
Recent car
'98 Volvo S70 2.5 10V Europa edition (Freya)
'83 Volvo 340 DLS 2.0 redblock (Loki)
Previous owned Volvo's
'96 Volvo 440 Si 1.8
'87 Volvo 340 GL 1.7
'85 Volvo 340 DL 1.4
Has thanked: 1613 times
Been thanked: 4075 times
brunocerous wrote: 20 Nov 2018, 15:18
bmdubya1198 wrote: 20 Nov 2018, 15:14 Usually I'm able to push the intake tube towards the manifold enough to slip the fan past. If you need to, you can remove the hose camp from where it attached to the ETM and slip that hose off, but the problem at that point is that it's much easier to do this when the fan is out of the way.
I can't stand the design of the '99+ intake.
Thanks! I had been nudging it over but didn't want to crack or dislodge the intake pipe. Even loosening the clamp and rotating it out of the way would help, but I can't see where it attaches.
The '99 intake is nuts!
Bruno , we should be doing PCV anyway on that new to you...once the manifold is off, easy Peazy. Ive got a spare ETM gasket, too.
brunocerous
Year and Model: 1998 V70
Has thanked: 303 times
Been thanked: 43 times
Post by brunocerous »
I managed to get to the starter in the '99 XC by removing the fan shroud first, then the fan assembly. Counterintuitive!
The starter came out after some coaxing with a dead blow hammer. I don't know if the metal bell-shaped piece was broken beforehand, but I managed to fish out the shard from the flywheel area.
The seller had intended to replace the starter before being dissuaded by the complexity and gave me the one he had bought from a junkyard. Who doesn't love a freebie?
Installation was a lot faster, but now nothing happens when I try to crank it. Hopefully, I'll have time to bring out the multitester before Thanksgiving dinner.
I also replaced the broken headlight switch. It works!
1999 Volvo V70 XC AWD engine bay
1999 Volvo V70 XC AWD starter, broken
1999 Volvo V70 XC AWD starter, old and salvaged
1999 Volvo V70 XC AWD starter installed
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
brunocerous wrote: 21 Nov 2018, 15:27 I managed to get to the starter in the '99 XC by removing the fan shroud first, then the fan assembly. Counterintuitive!
The seller has intended to replace the starter before being dissuaded by the complexity and gave me the one he had bought from a junkyard.
So it doesn't crank at all or it cranks and doesn't start? Same problem as before?
brunocerous
bmdubya1198 wrote: 21 Nov 2018, 15:30 So it doesn't crank at all or it cranks and doesn't start? Same problem as before?
Worse than before. When I saw the car, it turned over and sputtered. Now, nothing happens. It doesn't crank or click.
bmdubya1198
brunocerous wrote: 21 Nov 2018, 15:33
Hmm, that's weird. Are you sure everything is connected properly?
Maybe the new starter is a dud.
It can’t be since Bruno beach tested it first and it was fine.
I’ll throw my good one in the trunk, doing a drive by this holiday
I’ve got lots of good parts coming up from a Caravan through Mexico, seeking asylum from URO terrorist parts..striking terror into Volvo DIY
bmdubya1198
abscate wrote: 22 Nov 2018, 05:11 It can’t be since Bruno beach tested it first and it was fine.
Someone needs to stop URO!
theWIFES_S70
Year and Model: 1998 S70 base
Been thanked: 37 times
Post by theWIFES_S70 »
Is it an absolute PITA to check the starter for voltage without removing everything? I'm wondering if brunocerous bumped a ground somewhere. (When I replaced my front engine mount I tore through a ground that I didn't notice until after I put everything back together.)
And yes, I hope you bench tested that starter...
Happy Thanksgiving everyone!!!
Retired:
2015 Volvo S60, T5, 85K
bmdubya1198
Happy Thanksgiving!
