I have a 2002 V70 X/C AWD w/ 2.4T and automatic tranny. Can I switch the motor from a 2002 V70 into the V70 X/C? Both are 2.4T.
Can the automatic transmissions be interchanged. I know the AWD sections will not, but are the basic transmissions interchangeable?
V70 motor swap? Topic is solved
- Mike Langlois
- Year and Model: 2002 V70 & V70 XC
- Has thanked: 28 times
- Been thanked: 6 times
- Mike Langlois
Can motors (2.4 t) and basic automatic transmissions (not the AWD drive train) be interchanged in 2002 V70 and 2002 V70 X/c models?
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Yes. That car has no electronic AWD so dropping in the whole 2.4T engine/trans package will work and operate on the existing control modules. You can re-use the LH front cv axle to wheel but the AWD right side cv axle is not going to work with a FWD trans seal and will leak. If you get the RH cv axle with the eng/trans then you can do the whole transplant. Remove the driveshaft that runs from angle gear to rear and you're done.
- Mike Langlois
Great option for my Cross Country. I live n So Cal and may not need AWD. Picking up 2 V70's as parts cars and a spare drive train would be nice!
- 666 Views
Last post by rspi
- 740 Views
- 1344 Views
Last post by RickHaleParker
- 428 Views
Last post by miner1no
- 4772 Views
Last post by ARD-Lucky
