V70 motor swap? Topic is solved
Mike Langlois
Year and Model: 2002 V70 & V70 XC
Has thanked: 28 times
Been thanked: 6 times
Post by Mike Langlois »
I have a 2002 V70 X/C AWD w/ 2.4T and automatic tranny. Can I switch the motor from a 2002 V70 into the V70 X/C? Both are 2.4T.
Can the automatic transmissions be interchanged. I know the AWD sections will not, but are the basic transmissions interchangeable?
Mike Langlois
Can motors (2.4 t) and basic automatic transmissions (not the AWD drive train) be interchanged in 2002 V70 and 2002 V70 X/c models?
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
Yes. That car has no electronic AWD so dropping in the whole 2.4T engine/trans package will work and operate on the existing control modules. You can re-use the LH front cv axle to wheel but the AWD right side cv axle is not going to work with a FWD trans seal and will leak. If you get the RH cv axle with the eng/trans then you can do the whole transplant. Remove the driveshaft that runs from angle gear to rear and you're done.
Mike Langlois
Great option for my Cross Country. I live n So Cal and may not need AWD. Picking up 2 V70's as parts cars and a spare drive train would be nice!
