Real life example of what may happen when not using the anaerobic sealant for the cam cover
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
shodanx
Year and Model: xc70 2001
Post by shodanx »
Hello
First RTV silicone cures with moisture not oxygen
Second, the issue you have here, is excess sealant that got into some very poorly placed oil passages
If the anaerobic sealant part was the issue, it would not have gotten in the oil passages but rather you would have uncured sealant that didn't seal and eventually bypassed
Been thanked: 4071 times
Some good stuff from Permatex on the craft
https://www.permatex.com/ten-common-gasketing-mistakes/
oragex
Post by oragex »
Excess of sealant was definitely a problem. But I wonder if the right amount of RTV would have been fine for the cam cover?
My idea is the physical gap for this cover is very very small as it has a tight tolerance from machining. The contact surfaces are also quite large in some areas. This causes the sealant film to be extremely thin and wide. It may be the reason why a standard RTV may not cure properly as, as you mention, humidity doesn't reach deep enough inside the 'gap'. The car in the video came at the shop with oil leaking from the gasket which seems to mean the RTV can't cure properly inside such tiny gaps. Just a theory..
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
That guy sounds just like Michael Andretti. I didn't know he fixed Volvos on the side - busy guy.
