2006 V70 R Front Suspension
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
I'm a little confused with the suspension set up on the 2006 V70. I see complete lower front control arms offered, but I also see control arm bushings and replaceable ball joints. So, if I can replace the control arm bushings and ball joints, why (absent accident damage) would I ever need to replace the actual from lower control arms?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
Archer
- Year and Model: 2002 V70/S60 T5
- Been thanked: 5 times
Because it’s a lot easier to buy the whole control arm with bushings as opposed to removing and pressing in new ones...and it’s not that simple. I was going to do it and install Powerflex bushings in the front position, however, the metal sleeve has to be pressed out which requires a hydraulic press of and probably a jig of sorts to accommodate the curvature of the front arm. Anyhow, a new arm, Lemforder of course, is not too expensive.
- Year and Model: Lots
- Been thanked: 128 times
If you purchase genuine bushings and can have a garage press them in for you there is a big saving over the cost of a genuine control arm. Many garages press bushes in for the shade-tree mechanic for a few dollars.
I haven't replaced complete arms on any of our P2 vehicles. I have a small press that can handle the vertical V70/S60 bushings however it doesn't have the power for the XC90 bushings so I cut them out carefully with a hacksaw.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
If you have under 120k miles the ball joints may still be good. Anyhow, go with the good brands as above. The bj is Lemforder.
- 14 Replies
- 8557 Views
Last post by vtl
- 12 Replies
- 3429 Views
Last post by RickHaleParker
- 909 Views
- 3128 Views
Last post by oragex
- 1972 Views
Last post by skier518
