Help please - refresher on Odometer fix for 850
Koan
Year and Model:
Post by Koan »
It has been too long since I started this project, and I cannot remember the gear orientation for the infamous 850 odometer gear (1994 NA 855, 225,500 mi).:oops:
Can you explain which way the 12 tooth gear for a Volvo 850 faces as it is installed?
Does the flat side go toward the other large white gear or does the "bushing " side go toward the other large white gear?
Also - the "main" odometer seems to change at either .15 Mi or .5 mi on the trip odometer, I opted for it to change at one tenth. Have I installed the large gear back out of rotational sync? :?:
PS. While inside the dash, I mapped the polarity of most of the dash lights to install LEDs - I will post when complete, but this saves a ton of time so one can install the LED s once rather than trial and error. I will also show where I got the LEDs if it all works out.
Also - do remove the entire dash - I broke the plastic in front by not doing so. :idea:
Thanks!!!
tailor
Year and Model: 2004 XC90 2.5T AWD
Post by tailor »
1994 850 Auto Turbo wagon 306000km (Sold)
2004 XC90 AWD 188000km
"Life is like a reel to reel tape recorder,
the closer you get to the end,
the faster it spins."
Abe Gottschalk
Koan
Year and Model:
Post by Koan »
Tailor -
I appreciate your help - I read the links you suggest prior to my posting.
Maybe you could help interpret the pictures, but from them I still cannot tell which way the replacement gear is facing. Should your eyes be better than mine, maybe you can tell. :shock:
Thanks
tailor
Post by tailor »
Koan
Have a look here, maybe this will shed some more light on the subject.
http://volvospeed.com/vs_forum/index.ph ... =8398&st=0
http://volvospeed.com/vs_forum/index.ph ... 8398&st=20
I believe the orientation is displayed clearly here.
Hand wind the ododmeter to check that it changes correctly, if you need to re-orientate you can do so before closing everything up again.
If none of these help, show us some pictures :idea:
Tailor
Abe Gottschalk
Koan
Year and Model:
Post by Koan »
Thanks Tailor
I have it now, gear goes flat side down (towards other white gear)
Thanks for your help! :D
tailor
Post by tailor »
I am pleased that you got it all sorted out.
Just remember do not zero trip while moving or you will be back to square one.
Tailor
Abe Gottschalk
