13 S60 T5 AWD engine swap
Another question. There is a small box right after where the ground cable attaches to the -ve battery (on the cable connector itself). It has the number 31327698 on it. That number is for the entire ground cable. What's in that box? Is there any way to test it? I'm still thinking that I have a short somewhere. I still don't understand how I have continuity between my +ve terminal and a ground cable on the car. Is that normal?
Sounds like a computer - timing issue (since you ruled out cable connections, And the original issue happened due to the timing belt). Did you ever get it fixed? I'm assuming the pcm still thinks the cam shaft and crank shaft are out of sync and either the shafts need to be re-adjusted (hoping they are off by a single tooth), or the PCM needs to be reset.
- 479 Views
Last post by holyscrap
- 2419 Views
Last post by Krons
- 1431 Views
Last post by FLXC90
- 2009 Views
Last post by darylrobert
- 2106 Views
Last post by cdretc
