Kallekula's 2001 Wagon Relapse Topic is solved
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Just bought a new wagon! 106K and no compression on any cylinder :lol:
BMW 540i 2002
S70 Base 2000
Has thanked: 1609 times
Been thanked: 4065 times
That’s all right. It’s more important that they are close than exactly at spec , I’ve read
Probably top end from a timing belt failure?
kallekula
Post by kallekula »
abscate wrote: 05 Feb 2019, 04:07 That’s all right. It’s more important that they are close than exactly at spec , I’ve read
Yeah I guess. Timing belt has wear on outside, really not sure what’s going on. Belt maybe jumped a few teeth? I’m not gonna speculate very much, just pull the head off and see what’s going on.
BMW 540i 2002
S70 Base 2000
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
Those tyres look way too small as well.
kallekula
Post by kallekula »
Rattnalle wrote: 05 Feb 2019, 08:39 Those tyres look way too small as well.
It’s an XC AWD, think tire size is right.
BMW 540i 2002
S70 Base 2000
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
ZERO compression......that's interesting. I'd like to hear more about what's happened here. An old non-interference engine with a broken timing gear or similar will do that because the valve train isn't moving. But there might be one valve shut somewhere and you'd get a number.
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
Sounds like you did a compression test. Did you also check the timing?
It is possible, but doubtful, it is out of time. Still worth the work to double check your marks. I suppose someone may have had a bad pulley or tensioner - just replaced that and screwed it up. Checking the timing would eliminate this scenario.
Most likely, as speculated, the timing moved/belt broke and bent some valves. Someone may have put a used belt on to see if they got lucky or readjusted the belt/pulleys, learned they did not and sold it to your careful hands at a next to nothing price. What did you pay?
kallekula
Post by kallekula »
SuperHerman wrote: 05 Feb 2019, 11:12 Sounds like you did a compression test. Did you also check the timing?
Yeah I was thinking checking the timing before I tear it apart. Guy who sold it seemed honest, worked as a diesel mechanic and did the head 10k miles ago. Paid $500
BMW 540i 2002
S70 Base 2000
kallekula
Post by kallekula »
Daylight pics:
Oh, and yes it’s raining in California too :D
BMW 540i 2002
S70 Base 2000
Rattnalle
Post by Rattnalle »
kallekula wrote: 05 Feb 2019, 08:53
They look quite skinny for 215/65-16s which iirc is the correct size.
Looks really nice otherwise. Nice climate for the cars I guess. Some work on the black plastic and it'll look like new.
After you've found the whole compression issue ofc ;-)
