Kallekula's 2001 Wagon Relapse Topic is solved
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Parts run!
* Reinz head gasket kit
* Head bolts
* Timing belt kit
* Thermostat
* Spark plugs
So far only one trip to the junk yard to pick up a coolant bottle/Overflow reservoir.
Head coming off this Saturday, more pics to come🙂
BMW 540i 2002
S70 Base 2000
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Drain plug from trans is the same thread if the 26mm doesn't allow bulky spanners in there. They are 24mm though......
kallekula
Post by kallekula »
Every single intake valve bent. Never seen that before. All exhaust valves fine, maybe they never make contact because of their small size?
BMW 540i 2002
S70 Base 2000
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
kallekula wrote: 24 Feb 2019, 23:11 Every single intake valve bent. Never seen that before. All exhaust valves fine, maybe they never make contact because of their small size?
Intake jumped but the exhaust did not.
Active
Past
Has thanked: 1611 times
Been thanked: 4074 times
RickHaleParker wrote: 25 Feb 2019, 00:36
:D
Throw that Reinz head gasket away and get a Volvo one, or consider the first pass at the head gasket, a practice run
:shock:
kallekula
Post by kallekula »
abscate wrote: 25 Feb 2019, 02:27
:D
:shock:
Always used Reinz, maybe Elring some time, and I’ve never had a problem?
BMW 540i 2002
S70 Base 2000
kallekula
Post by kallekula »
Yes that has to be it.
BMW 540i 2002
S70 Base 2000
kallekula
Post by kallekula »
Got head back from machine shop. Used a new one this time that I was recommended. The shop I used to go to did some crappy work in the past.
Pics:
BMW 540i 2002
S70 Base 2000
You almost hate to put that back on....
kallekula
Post by kallekula »
abscate wrote: 06 Mar 2019, 15:14 You almost hate to put that back on....
I know...
BMW 540i 2002
S70 Base 2000
