Hi...
I just posted this in the wrong place on an old post... sorry about that..
But here is my Question can anyone tell if the VVT Hub rotation is a Smooth action?
I feel a Roughnees as a turn it back and forth.
I started to experience a roughness in my engine a few weeks ago did all the normal checking Vacuum leak,Duct work leak, Spark plugs, Coils, PVC system, timing check.... Unable to find anything wrong... Now I got a Check engine Light , Code P0016. Oil is a few weeks old Mobile 1.
Every sensor has been replaced (3) (Got Spares from Less mileage cars..) Both sensors on the Front and Rear Exhaust Cam and Checked the Screen on the oil port, both Sensors are fine. Crankshaft sensor I metered out and compared to 2 others same Readings but replaced it anyways.
So now I got the timing belt off again and i don't remember when I replace the head if the VVT Hub had this Feel or if it was spring loaded, Should it be a Smooth turning Action.?
Anyone?? 02 V70 xc auto.
Thanks Guys..
Jay
2002 V70 xc. VVT Hub 5030523 9497786
I might have a spare off the car I can check
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Without the belt on it, it should spring back and forth pretty smoothly, I don't remember any significant roughness. Obviously, I'm talking about a little movement, before it hits the opened valves
mrjay62
- Year and Model: V70XC 2002
- Been thanked: 3 times
Ok
I think it's shot what should be that spring action is gone and it is a rough feeling as i rotate it counter clockwise. . The cams are locked with the cam lock tool...
Now to find a used one , unless Abscate has one for sale...
Thank you Oragex.
Thank you Oragex.
I think it’s pretty smooth. Pull the part number off it of you can see it, I think I have an intake CVVT from my 1999 401k parts car, though.
On edit. Found part number 5030523 on your other thread
mrjay62
Hi Abscate/Steve
I'll check for the numbers now..
That's alot of miles...
Would you reuse it on your own car?
Hate to have to redo this anytime soon....
What are you asking for it?
PM me or email [email protected]
Thanks
Jay
Thanks
Jay
mrjay62
Hi Abscate
I found a vvt hub looks like new same part number from a 03 v70 xc. Froze my feet and fingers getting it off... what a pita. !
I'll update if this resolves the engine running rough or not...
Thanks guys
Thanks guys
Ill fix part numbers, thanks
- 1895 Views
Last post by Mikaro07
- 1894 Views
- 8799 Views
Last post by dono
- 826 Views
- 5171 Views
Last post by LT South Africa
