How did you determine that the used one is working correctly?
Hell no! First off, that would be treating the symptoms not fixing the cause. Second off, changing the position of the cam will not change its response time. If that guy was their mechanic and not one of the grease monkeys, it is no wonder that shop is out of business.Idamon wrote: 29 Mar 2019, 17:49 I talked to their mechanic who suggested loosening the timing belt and moving the exhaust cam one tooth either way to see if that solves the issue. Does anyone agree with that approach? Thanks!
