With this code
is it to one or the other? (A or B )
or how should i test those?
Code P0027, which solenoid ?
- RickHaleParker
- Been thanked: 978 times
P0026 Intake (A).
P0027 Exhaust (B).
P0027 Exhaust (B).
Active
Past
Past
Mikele82
- Year and Model: XC70 04 + C30 T5 08
- Has thanked: 30 times
- Been thanked: 3 times
Any idea of a good way to release the bolt on B?
i cant seem to be able to release it, not manually and not with impact driver drill. its just on the edge of breaking the hex teeth...
- RickHaleParker
If you are using a Hex bit you are using the wrong tool. It is a Torx so use a Torx bit. If a Torx bit will not break it loose. Heat it with a Micro torch for 90 seconds. Then turn counterclockwise.Mikele82 wrote: 04 Sep 2020, 20:25 Any idea of a good way to release the bolt on B?
Active
Past
Past
- 8411 Views
Last post by RickHaleParker
- 23 Replies
- 10277 Views
- 1515 Views
Last post by draser
- 1607 Views
- 1341 Views
Last post by JIMMYCNOTES
