Voltage drop when AC on but no battery dash light
Kags1969
Year and Model: 2004 v40
Post by Kags1969 »
I purchased a 2003 V40 for my sister and am trying to get it to a good spot where she can drive it worry free for a while. Here is the issue that I am noticing.
Using a ScanGauge2 to monitor:
~13.7 on startup drops to 12.7-13.0 during AM commute in (typically no ac)
On commute home (low rpm) 12.7 is normal unless I run the AC at which point it will drop to 11.8-12.0
I can shut off the AC and the voltage will come up to 12.2-12.4 (at idle - low rpm commute speeds)
Not sure if this is a voltage regulator issue or an alternator issue. Any sage advise?
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Before you start throwing money and parts at it. Clean the battery terminals and the electrical connections to the alternator. Inspect the cables to both for damage. Voltage drops under load can be something that simple.
Active
Past
Kags1969
Post by Kags1969 »
Will do. Thanks, Chris
