I purchased a 2003 V40 for my sister and am trying to get it to a good spot where she can drive it worry free for a while. Here is the issue that I am noticing.
Using a ScanGauge2 to monitor:
~13.7 on startup drops to 12.7-13.0 during AM commute in (typically no ac)
On commute home (low rpm) 12.7 is normal unless I run the AC at which point it will drop to 11.8-12.0
I can shut off the AC and the voltage will come up to 12.2-12.4 (at idle - low rpm commute speeds)
Not sure if this is a voltage regulator issue or an alternator issue. Any sage advise?
Voltage drop when AC on but no battery dash light
- RickHaleParker
- Been thanked: 979 times
Before you start throwing money and parts at it. Clean the battery terminals and the electrical connections to the alternator. Inspect the cables to both for damage. Voltage drops under load can be something that simple.
Active
Past
Past
- 1356 Views
Last post by RavagedPheonix
- 28 Replies
- 11941 Views
- 21 Replies
- 3224 Views
Last post by MrAl
- 2001 Views
Last post by dj_v70
- 11 Replies
- 1859 Views
Last post by shegarty
