Door Handle Does Nothing
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Re: Door Handle Does Nothing
Post by MrAl »
Hey does anyone know for sure the Torx size bit for the one screw in the door panel?
The web gives mixed results.
MrAl
Post by MrAl »
Hi,
Since nobody answered i guess i will just have to wing it.
I might get out there later, once i find out what size it is i'll post here so others will know too.
Has thanked: 1498 times
Been thanked: 3810 times
Take a picture of the bolt in question and I’ll measure on my T5 tonight
MrAl
Post by MrAl »
Hi,
I went out there and played with it. I found it was really T25 but some sites quote T15.
T25 fit good.
But the problem was that there is a 'wire' cable similar to the hood release cable. The end popped out of the socket it fits into in the door handle you pull out to open the door from the inside.
The reason for that however was that there was some sort of 'clip' that holds it from popping out and it appears to be broken. I am not sure where to get another clip or what it really looks like because it was in pieces that fell apart in my hand.
I stuck the end of the wire back in just to see what would happen and how it works and it will work again if i get a new clip.
I guess i'd need a blow up drawing of that door handle mechanism, just behind the door pull handle on the inside.
I tied it in temporarily but it reallky needs that clip to ensure it works for a long time again.
Any ideas how to see what the clip looks like or where to get one?
Thanks.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2652 times
Been thanked: 1240 times
Post by matthew1 »
Also -> Amazon link
MrAl
Post by MrAl »
matthew1 wrote: 25 Jun 2019, 14:45 Does this help? S60 Inside Door Handle Fix
Hi Matt,
Thanks. That looks a little similar, but they are not showing the clip.
It does seem though that they are doing their own little fix. Which i guess i will have to do too without the clip unless i can find a drawing for this actual car. It's a v70 1998.
Thanks again.
matthew1
Site Admin
Post by matthew1 »
Oh sorry MrAl, for some reason I had it in my head you were talking about/own a P2.
Also -> Amazon link
Piece of tape or a zip tie to secure the control rod?
Take some pictures or find a diagram for reference?
If you pull on a door knob in a forest and nothing happens, does a Volvo somewhere else start to warm the third rear seat?
Eric? Are you there?
MrAl
Post by MrAl »
abscate wrote: 26 Jun 2019, 04:31 Piece of tape or a zip tie to secure the control rod?
Hi there,
Well yes i have it jury rigged for now but i was hoping to get the original part so it stays working for a long time.
If that is possible of course.
That drawing isnt the same either though but thanks.
Maybe i make a drawing so it becomes clear.
MrAl
Post by MrAl »
Hello again,
Here are three photos.
The one on the far left shows the mechanism before it is removed from the door. You cant see the part in question until that whole piece is removed as shown in the center photo.
The center one has a light blue rectangle drawn around the area in question.
The one on the far right shows the little thing that pops out because something is missing from what holds it in place. The little end is right between his two fingers.
