Could this be it?
#25 in diagram, link to Tasca parts below.
https://www.tascaparts.com/oem-parts/vo ... wtbDUtZ2Fz
Door Handle Does Nothing
- gmh
- Year and Model: 2016 XC60 T5
- Has thanked: 28 times
- Been thanked: 22 times
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-2025) sold to Matthew
2014 XC60 T6 (2017-present)
2016 XC60 T5 (2024-present)
1969 145S (1987-91)
1973 145E (1989-90)
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
Hi,
That looks sorta like it but not exact. I cant tell what part is needed from that.
I guess i'll just have to rig it up and that will have to be that.
Otherwise i would need a really good drawing or someone that did this before.
I dont want to have to take the other door apart just to find out what i need either.
Thanks though.
Thanks though.
- Has thanked: 1611 times
- Been thanked: 4072 times
let me peek at my spare door, Al...hang on.
- MrAl
Oh thanks.
- MrAl
Hi again,
I am starting to think that maybe the housing that holds the end of the cable was broken. So maybe there is no 'clip' maybe it is the housing itself that broke. It's too hard to tell by looking at the broken one and the drawings on the web just are not good enough, they are more like cartoon drawings than photos that's what doesnt work i guess.
But if this is true, i dont think i'd want to buy a whole new housing or even get one from the junk yard if they had one that is. It would be much more work then simply applying some epoxy or something like that.
I'll look around the web a little bit more but if anyone has a better drawing that would help, thanks.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
- MrAl
Hi,MoVolvos wrote: 13 Jul 2019, 00:51 _
See if this helps?
_
https://www.volvopartswebstore.com/show ... evel=24677
Thanks for the drawing. I think that is the right one this time.
I am posting two pictures, the first -2 is the same picture with the end of the cable highlighted with a red square showing the very end in question.
The second picture -3 is the same picture as -2 but with the "clip" or whatever it is highlighted within the red square in green. You have to look close to see it, but the very top of the end of the cable looks like it has a rectangular clip on top of it (green). This may be a clip or it may have been part of the cable. If it is part of the cable, then it looks like a whole new cable would have to be installed.
Thanks again.
Any ideas appreciated.
- DoorLockMechanism_98V70-3.gif (105.71 KiB) Viewed 941 times
- DoorLockMechanism_98V70-2.gif (105.51 KiB) Viewed 941 times
- MrAl
Hi,
Were you able to see that part in your door yet?
If so, is that 'clip' in the drawing really a separate
piece or is it part of the end part of the cable?
I took a picture but couldn't see much, stand by
If a Volvo handle is pulled and does nothing, does a tree fall in a Swedish forest, making no sound?
