Pinging sound 1998 V70R
When I turn the wheel and back up I hear a metallic ping. When I turn the wheel back to center and drive forward it happens once more. No noises when driving or turning, only when backing up and turning and then driving forward. It doesn't do this when going in reverse without turning the wheel or driving forward without turning the wheel, just when I back out of my driveway and take off. Thoughts?
- Has thanked: 2199 times
More likely the viscous coupling. Check the front bearing on it.
Yes you do, but you may be able to feel the bearing wear by jacking all 4 wheels off the floor and turning the prop-shaft. Realistically though removing the prop-shaft from the viscous coupling and then the coupling itself is the best way. In my case once the VC was removed from the carrier the bearing balls just fell out.
- 3877 Views
Last post by eythorsig
- 10 Replies
- 1887 Views
Last post by erikv11
- 1668 Views
Last post by polskamafia mjl
- 10 Replies
- 5659 Views
Last post by JimBee
- 1549 Views
Last post by azureblue
