Loosen ANY lug nut
dalel
Year and Model: 1998 V70
Been thanked: 3 times
Re: Loosen ANY lug nut
Post by dalel »
cn90 wrote: 03 Sep 2019, 19:40 - I always add a tiny bit of wheel bearing grease (about one drop). This way next time it is easier. Have used this trick for 30 years.
- Don't scratch the paint work with your breaker bar!
- A guy on youtube used floor jack to undo the AXLE NUT and it work, see video below...
cn90, good to see you again. I still owe you for the relay. I'd still be glad to paint a car for you. This is my V70... with a few extra pieces...
amblerman
Year and Model: 1999 s70
Has thanked: 2 times
Been thanked: 70 times
Post by amblerman »
dalel wrote: 03 Sep 2019, 20:36
Great picture.. quite a lot of interesting mods going on there.. Can't imagine you get much life out of the tires though. ;-)
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
Ultimately the lugs shouldn't be on that tight... In a jam this is a great idea.
dalel
Post by dalel »
amblerman wrote: 04 Sep 2019, 02:47
Thanks. You can't see the interior mods in that painting... like... I replaced the CEL.
wizechatmgr
dalel wrote: 04 Sep 2019, 14:52
Should replace that with one that says FCP =P
Been thanked: 472 times
Post by cn90 »
When I buy any used car, this is what I do for the wheels to avoid seized wheels:
1. Jack up each wheel.
2. Remove all the lugs and remove the wheel.
If the wheel is seized onto the hub (snow area with salt), there is trick in forum to undo it, search for the tricks.
3. Apply anti-seize around the hub bore. Also a bit of anti-seize on each lug (about "one drop" of anti-seize).
4. Now your wheel can be replaced in the middle of nowhere without being seized.
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
This $hit works really good:
BMW 540i 2002
S70 Base 2000
amblerman
Post by amblerman »
Ha! I like that. nice job.
