Correct torque for head bolts?
Jibbaman150
- Year and Model: 2005 xc70
I have definitely researched this topic. Most of what read is 15 ft lbs first pass 44 ft lbs second pass then 130 degrees, on my 2005 xc70. Problem is that the machine shop I took my head to printed me out all my engine specs from AERA engine builders association. On the print out it says 15 ft lbs, 30 ft lbs, then 130 degrees. (30 not 44) so just looking to get some clarification from someone who’s done this before. Thank yal!
gcha8e
- Year and Model: 2005 S60 2.5T AWD
- Has thanked: 20 times
- Been thanked: 2 times
Go up to 30, then the 130 degrees, if it feels right, keep it, or if not, give it another 45 degrees turn. You'll be fine. (no I have not done it before)
- RickHaleParker
- Been thanked: 978 times
Per Volvo Vida:
Tighten the screws in sequence from the center and outwards.
Stage 1........20 Nm (15 Ft-lbs)
Stage 2........60 Nm (44 Ft-lbs)
Stage 3........130°
Stage 3........130°
Active
Past
Past
- greg850r
- Year and Model: a long list
- Has thanked: 5 times
- Been thanked: 26 times
I always use 44ft-lbs for the last torque before putting the dial on it.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
Jibbaman150
Thanks guys, thanks Rick for the Vida reference.
Hey does anyone know what the cross-hatching is supposed to look like on the cylinder walls? Mine are at about a 60 degree angle and almost look like scratches. I have some pictures just got to figure out how to upload them.
- RickHaleParker
1. [Full Editor & Preview] Scroll down it is below the default editor.Jibbaman150 wrote: 03 Nov 2019, 09:24 I have some pictures just got to figure out how to upload them.
2. Scroll down [Attachments]
3. [Add Files] select the pictures.
4. [Place inline]
5. [Preview]
6. Make formatting adjustments as needed.
7. [Submit]
Active
Past
Past
Typical error on torque wrenches is 25%, so don’t get too hung up trying to get these settings “ exact”
Try to be consistent, rather than exact. On the head, torque even-ness is more important than actual value,within reason. New bolts too, please.
Jibbaman150
Francisco1999
- Year and Model: 2016 v40 2.0t
Hola
Yo necesito el apreté de la culata del v40 2016 2.0t B4204T19
Francisco1999
Hola
- 1305 Views
Last post by Nevada1906
- 1367 Views
Last post by erikv11
- 2764 Views
Last post by FLXC90
- 9 Replies
- 4704 Views
- 2831 Views
Last post by chrism
